LabWindows/CVI
"...handle is invalid" : Error only when closing the Application, at RunTime everything seems fine...
Hello ,
I am using CVI2010 and trying to use Control Array but I am stuck with "Resource Invalid error".
I can't create the control array handle. Did I miss somthing? I assined the buttons to CTRLARRAY.
Thank you,
Insuk
My header file has both Panel and Control array constants:
#define  PnlDigCNC                               2
#define  PnlDigCNC_STRING                 2       /* control type: string, callback function: (none) */
#define  PnlDigCNC_TOGGLEBUTTON_8         3       /* control type: textButton, callback function: (none) */
#define  PnlDigCNC_TOGGLEBUTTON_7         4       /* control type: textButton, callback function: (none) */
#define  PnlDigCNC_TOGGLEBUTTON_6         5       /* control type: textButton, callback function: (none) */
#define CTRLARRAY 1
Source file :
if (pnlDigCnCHandle == 0){
    if ((pnlDigCnCHandle = LoadPanel (0, "Cnc.uir", PnlDigCNC))<0)
     return -1;
   DisplayPanel(pnlDigCnCHandle);
   if (pnlDigCnCHandle > 0 ){
    DigSWarray = GetCtrlArrayFromResourceID (pnlDigCnCHandle,CTRLARRAY );
Error :
Library function error(return value == -24) Resource ID not found in user interface resource file.
Message 11 of 13
(1,079 Views)
Hello momo2013 / Insuk,
why don't you start your own new thread instead of hijacking this one - I don't see any relation between these two topics... Aslo have a look here
Concerning your question, your constant probably is wrong, I would assume that it should be something like PANEL_CTRLARRAY
Message 12 of 13
(1,075 Views)
Continues here
Message 13 of 13
(1,057 Views)
