LabWindows/CVI
sppression of NON-FATAL RUN-TIME ERRORS
It is useful to the NI-DAQ function WFM_Check() to see if there is a transfer currently in progress. It is also convenient to work in debug mode. Unfortunately, when CVI is in debug mode and WFM_Check() is called and the result is noTransferInProgError, execution is paused and a NON-FATAL RUN-TIME ERROR dialogue appears. I would perfer that the function simply provide a return value corresponding to this condition and not pause execution. Is there a way to tell CVI in debug mode to suppress all NON-FATAL error notificatoin or better still to change the way that it responds on a function by function basis? Thank you.
Joe Briton
(2,806 Views)
You need to be careful ignoring all non-fatal runtime errors. Those error dialog boxes can be a big help in debugging unexpected conditions. But for functions whose error you expect and are ready to handle, do something like this.
int bPrevBreak;
// don't break on errors, but save previous state
bPrevBreak = SetBreakOnLibraryErrors (FALSE);
// functions whose errors you'll handle in code
// restore previous state of break-on-errors
SetBreakOnLibraryErrors (bPrevBreak);
(2,806 Views)
