04-09-2012 12:42 PM
Does anybody know how to turn on the tool tips (the one-line notes that appear when you put the mouse cursor over a button or toolbar item) for the toolbar in a program that I've written? I can load the toolbar fine, but there doesn't seem to be any way to turn the tips on.
04-11-2012 06:40 AM
04-11-2012 02:58 PM
Toolbar tooltips are specified by the Description parameter of the Toolbar_InsertItem function or the TOOLBAR_ATTR_DESCRIPTION attribute. Setting the TOOLBAR_ATTR_DESCRIPTION to NULL disables the tooltip. A good example of toolbar tooltips can be found in the C:\Users\Public\Documents\National Instruments\CVI2010\samples\userint\custctrl\toolbar\tooldemo.cws example.
Guillaume, could you describe your problem in a little more detail or provide an example?
