04-12-2012 09:45 AM
I'm using LabWindows/CVI 8.1
My application is a simple serial communication to a circuit.
Previously, the serial application used Windows 32 serial communication (w32sc), which worked well.
Old Code Sample:
status = w32sc_open(comm, baud); // open the desired comm at the selected baud
status = w32sc_setparity(parity);
out_buf[0] = 0x19;
bytes_sent = w32sc_write(&out_buf[0], 1); // send the address
bytes_read = w32sc_read(&echo_buf[0], 1);
The byte is sent and the circuit responds within 3 msecs. More data is sent after that.
Now the application requires Visa for the serial communications:
New Code Sample:
// create a VISA session to the serial port and return a handle to it
int init_comm(long baud, int parity)
status = viOpen (defaultRM, (ViRsrc)Ports[comport-1], VI_NULL, VI_NULL, &serialHandle);
status = viSetAttribute (serialHandle, VI_ATTR_ASRL_PARITY, (ViUInt16)parity); // Parity is Mark
status = viSetAttribute (serialHandle, VI_ATTR_ASRL_DATA_BITS, 8);
status = viSetAttribute (serialHandle, VI_ATTR_ASRL_BAUD, (ViUInt32)baud); // Baud is 4800
status = viSetAttribute (serialHandle, VI_ATTR_ASRL_STOP_BITS, VI_ASRL_STOP_ONE);
status = viSetAttribute (serialHandle, VI_ATTR_ASRL_FLOW_CNTRL,VI_ASRL_FLOW_NONE);
status = viSetAttribute (serialHandle, VI_ATTR_ASRL_END_IN, VI_ASRL_END_NONE);
status = viSetAttribute(serialHandle, VI_ATTR_TMO_VALUE, 5000);
sts = viOpenDefaultRM (&defaultRM);
sts = init_comm(4800, VI_ASRL_PAR_MARK);
out_buf[0] = 0x19;
vistatus = viWrite (serialHandle, &out_buf[0], 1, &bytes_sent); // send the address
vistatus = viRead (serialHandle, &echo_buf[0], 1, &bytes_read);
After the byte is written it now takes over 12 msecs for the byte to be read in viRead, causing a timeout on the cricuit that the data is being sent to.
Why is there such a bigger delay reading the byte that was written compared to the old way? A difference of 9msecs.
Hope this is enough information.
Thanks!
John W.
04-13-2012 01:38 PM
Hello John,
NI-VISA is an API that is much more complex then the w32sc. It allows us to communicate with any instrument over any bus, and move code from one bus or platform to another without making many changes. I am pretty sure this additional delay you are experiencing is related to the additional complexity of the VISA API and perhaps additional function calls that haven't been as optimized for serial communication as the serial specific Windows API.
For more details, I would need to talk to R&D. What version of NI-VISA are you using?
04-13-2012 02:30 PM
Thanks for the reply.
The visa version is 4.1
If the Visa doesn't work out, can you recommend a different serial comm. for me to use?
Thanks!
JW
04-13-2012 05:48 PM
Have you already tried using CVI standard RS232 library?
04-16-2012 06:16 AM
That's probably what I am going to have to do.
JW
04-17-2012 11:47 AM
I quickly implemented a simple RS232 interface usin the CVI standard rs232 library.
Here is the problem I am now having.
We use the parity bit to distinguish between an Address and Data. We use "Mark Parity" for Address and "Space Parity" for Data
Ist setup the comm port using Mark Prity to send the address:
sts = OpenComConfig(1, "COM1", 4800, 3, 8, 1, 10, 10);
Write the Address:
result = ComWrt (1, &out_buf[0], 1);
Then change to Data using Space Parity:
sts = OpenComConfig(1, "COM1", 4800, 4, 8, 1, 10, 10);
Write the data:
result = ComWrt (1, &out_buf[1], 2);
The problem is that it is taking a long time, about 30msecs to close and open the comm port to change the parity bit.
Is there a way to change the parity bit without closing and re-opening the comm port?
Thanks!
John W.
04-18-2012 03:07 PM
Hello John,
Looking at the given RS-232 functionality the only way to change the Parity in the connection would be closing and reopening.
Daniel
