LabWindows/CVI
way to determine time a device in enabled?
This seems like it should be rather simple, but I'm having a tough time figuring out a solution....
I'd like to be able to have 2 timers on my user interface.  One timer will display the total time since the application was started, and the second timer will show the total time that a device is enabled (device will be enabled and disabled numerous times).  Determining the total time since the application was started is a simple task:
startTime = Timer();
CVICALLBACK tlmTimerCallback() {
     totalTime = Timer() - startTime;    // Elapse time (mS)
However, I'm having a difficult time figuring out how to get a new start time when the device is re-enabled so that I can then add the new elapsed enable time to the previous enable time. Millisecond accuracy is nice, but 1 second accuracy would be fine too.
Any help would greatly appreciated.
THANKS!!
(3,479 Views)
Accepted by topic author byrd01
I made a small application with CVI 8.5.1 for this purpose.
Please check the attached project and see if it answers your question.
S. Eren BALCI
IMESTEK
(3,467 Views)
Thanks for the example.  Unfotunately, it doesn't seem to want to run on my computer.  When I try to build the project, I get link errors (undefined symbol, one each for NewAsyncTimer, DiscardAsyncTimer, and SetAsyncTimerAttribute).  I'm running LabWindows/CVI 8.1 (base package).  At first I got an error when opening the uir file as well, but I saved it as an 8.1 file, and that seemed to help.   The asynchronous timer help files as well as asynctmr.h seem to be a part of my CVI install, so it appears that the functions should be supported by 8.1.  I'm not sure how the solve the error though.
I'm hoping I can get this running.  After seeing them mentioned a number of times, I still am not overly clear on what the advantage of asynchronous timers are.  This will be a good example to get a little experience using them.
(3,463 Views)
I solved my link problems.  I had to add the asynctmr.fp instrument driver to the project.  Now it runs, and seems to work fine with my newly created (8.1) uir file.  Thanks again.  I'll go take a look at the example now and let you know how it works out.
(3,453 Views)
Thanks ebalci!  I integrated parts of your example into my project over the weekend, and it works great.  I have another project that I'm working on that sends commands and recieves telemetry to a number of devices (8 to 10) via TCPIP.  The user interface tends to be slow while all the TCPIP connections are being maintained.  I think the Asychronous timers might help with that project as well.  That leads to some other questions, but I'll save those for another post after I do some more reading on the subject.  Looks like there are some good articles in the NI Developer Zone.
Thanks again!
(3,418 Views)
You are welcome..
I'm glad it helped you figure things out a little.
Take care,
S. Eren BALCI
IMESTEK
(3,403 Views)
