Linux Users
Install ni-serial driver to ubuntu 22.04.03
I try to install the ni-serial driver on my Ubuntu 22.04.03.
On my OS I have two kernel: linuz-6.2.0-26 and linuz-6.5.0-25.
On boot/grub I choice the 6.2.0-26 kernel and try to install the driver.
1) download from the NI site the ni-serial "NILinux2023Q4DeviceDriver.zip" and install it (without problem).
2) sudo apt update
3) sudo apt install build-essential
4) sudo apt install linux-headers-$(uname -r)
5) sudo apt install ni-serial
on last step (5) I had this issue (cat /var/lib/dkms/nikal/23.8.0f102/build/make.log):
Making nikal.ko
warning: the compiler differs from the one used to build the kernel
The kernel was built by: x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
You are using: gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
CC [M] /var/lib/dkms/nikal/23.8.0f102/build/nikal.o
MODPOST /var/lib/dkms/nikal/23.8.0f102/build/Module.symvers
ERROR: modpost: "__pte_offset_map" [/var/lib/dkms/nikal/23.8.0f102/build/nikal.ko] undefined!
make[2]: *** [scripts/Makefile.modpost:144: /var/lib/dkms/nikal/23.8.0f102/build/Module.symvers] Error 1
Do you have any idea?
Thank you
(759 Views)
Please use the 2024Q1 driver stack.  It has been updated for more recent kernels.
(756 Views)
