12-15-2023 04:05 AM
I would like to use the NI-DAQmx on Ubuntu 22.04. It seems to work fine with the original kernel, v5.15 (to be precise, v5.15.0-91). However, if I use the newer kernel, from the "hardware enablement" stack, v6.5, the dkms modules fail to build. Essentially, when building nikal, it fails with:
CC [M] /var/lib/dkms/nikal/23.8.0f102/build/nikal.o
MODPOST /var/lib/dkms/nikal/23.8.0f102/build/Module.symvers
ERROR: modpost: "__pte_offset_map" [/var/lib/dkms/nikal/23.8.0f102/build/nikal.ko] undefined!
make[2]: *** [scripts/Makefile.modpost:144: /var/lib/dkms/nikal/23.8.0f102/build/Module.symvers] Error 1
make[1]: *** [Makefile:1989: modpost] Error 2
This newer kernel does work better with my computer, so I'd rather use that one if possible. Is this error known? Is there already a plan to support this newer kernel soon?
Best,
Éric
Solved! Go to Solution.
12-15-2023 11:15 AM
This is a known issue. I would expect this to be corrected in the coming quarterly driver stack release. In the mean time, if you can somehow use the 6.2 HWE kernel, that may work.
01-25-2024 04:35 PM - edited 01-26-2024 08:52 AM
@pieleric The landing page hasn't been updated yet (that's coming very soon), but the Linux driver feeds have been updated for 2024 Q1. The top-level Ubuntu 22.04 package can be found here: http://download.ni.com/ni-linux-desktop/2024/Q1/ni-ubuntu2204-firstlook-drivers-2024Q1.deb
Edit: The landing page now has links to the 2024 Q1 drivers: https://www.ni.com/en/support/downloads/drivers/download.ni-linux-device-drivers.html
