09-02-2024 04:55 AM
Not really a question, but more a note, for those who are also facing the same issue.
Ubuntu 22.04 just got an updated HWE kernel (beginning of August), from 6.5 to 6.8. That's the also the kernel which is used on Ubuntu 24.04 LTS.
However, with our systems, using a PCIe 636x, although the NI-DAQmx drivers do compile, they fail to work properly.
We see such error:
File "/usr/local/lib/python3.10/dist-packages/nidaqmx/stream_writers.py", line 398, in write_int16
return self._interpreter.write_binary_i16(
File "/usr/local/lib/python3.10/dist-packages/nidaqmx/_library_interpreter.py", line 5968, in write_binary_i16
self.check_for_error(error_code, samps_per_chan_written=samps_per_chan_written.value)
File "/usr/local/lib/python3.10/dist-packages/nidaqmx/_library_interpreter.py", line 6410, in check_for_error
raise DaqWriteError(extended_error_info, error_code, samps_per_chan_written)
nidaqmx.errors.DaqWriteError: A hardware failure has occurred. The operation could not be completed as specified.
Task Name: AO
The kernel log shows:
kernel: [ 218.402117] DMAR: DRHD: handling fault status reg 3
kernel: [ 218.402131] DMAR: [DMA Read NO_PASID] Request device [01:00.0] fault addr 0x148df5000 [fault reason 0x06] PTE Read access is not set
The NI "platform roadmap" states that only kernels 5.15 and 6.2 are supported (for now), so that issue is not really surprising (and maybe the surprising part is that it did work on v6.5). https://www.ni.com/en/shop/software-portfolio/platform-roadmap.html
The roadmap states that the Ubuntu 24.04 LTS kernel is 6.2, though that's actually 6.8, so probably it will be something looked into soon, for Q4?
I guess, for our side, the lesson is that really, with the NI-DAQmx drivers, only the LTS kernel can be used on production systems.
Cheers,
Éric
09-03-2024 08:40 AM
Ubuntu 24.04 has begun enabling DMA remapping by default. Many NI drivers do not support DMA remapping. "DMA is not working with NI Drivers on IOMMU-enabled systems" on the 2024 Q1 Known Issues page has more information and a potential workaround.
09-09-2024 09:09 AM
Thanks a lot GabeJ, that did work.
We'll switch the production systems the LTS kernels anyway, at the ones where the hardware is supported because apparently the kernel updates can break things a little bit too easily...
10-18-2024 08:20 AM - edited 10-18-2024 08:32 AM
Just wanted to mention I have the same Issue with Ubuntu 24.04.1 LTS (Noble Numbat) and Kernel 6.8.0-47-generic.
I have a python script, that creates this error:
Task Name: voltage-sweep
Status Code: -5015
sudo journalctl --system -f
I can relate this message to this messagekernel: niraptnonusb 0000:04:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000c address=0x1133cd000 flags=0x0000]
kernel: niraptnonusb 0000:04:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000c address=0x1133db000 flags=0x0020]
Your message is different, thats why I did not find the error before via grep.
Are You using a Intel CPU? Maybe thats the reason for the different messages
This guide solved the issue for me, too.
10-18-2024 08:35 AM
Yes, here I have an Intel CPU. That could well be the reason for difference of logs.
Eventually, passing "iommu=pt" as kernel option (by editing /etc/default/grub) works fine.
10-18-2024 08:53 AM - edited 10-18-2024 08:54 AM
Yes 🙂
I created a ansible playbook to automate installing nidaqmx on ubuntu machines. Thought I share it here.
Unfortunately I cant create a new topic. Before I forget I just post it here:
# Attention! Spacing ist very important!
- hosts: labpc
become: true
tasks:
- name: Install nidaqmx
block:
- name: Install signing key for ni repo
ansible.builtin.template:
src: templates/ni-driver/ni-software-2024-noble.asc
dest: /usr/share/keyrings/ni-software-2024-noble.asc
owner: root
group: root
mode: '0755'
# Get the signing key and source list entry from existing installation
- name: Install template for ni repo
src: templates/ni-driver/ni-software-2024-noble.list
dest: /etc/apt/sources.list.d/ni-software-2024-noble.list
owner: root
group: root
mode: '0755'
- name: Install ni-daq package
ansible.builtin.package:
name:
- ni-daqmx # ni driver
state: latest
update_cache: yes
- name: NI Driver install
ansible.builtin.command: dkms autoinstall
# Apply workaround https://www.ni.com/docs/en-US/bundle/ni-platform-on-linux-desktop/page/iommu-linux.html
- name: Apply DMA workaround
block:
# https://stackoverflow.com/questions/55844981/ansible-insert-word-in-grub-cmdline
- name: Enable IOMMU via grub
ansible.builtin.lineinfile:
path: /etc/default/grub
regexp: '^GRUB_CMDLINE_LINUX_DEFAULT="((?:(?!iommu=pt).)*?)"$'
line: 'GRUB_CMDLINE_LINUX_DEFAULT="\1 iommu=pt"'
backup: true
backrefs: true
notify: update-grub
- name: Update grub
ansible.builtin.command: update-grub
become: yes
- name: Reboot machine
ansible.builtin.reboot:
reboot_timeout: 3600
11-19-2024 12:28 PM
Hey nikongen,
Do you mind sharing the python script you used to reproduce this error? I believe we are experiencing a similar issue, but it seems to happen intermittently and are struggling to reproduce the issue consistently. This has made it quite difficult to validate any changes that we make to our system.
Thank you!
