Lookout
Creating ActiveX graphic object in Lookout 4.5
I have been using Lookout 4.5.1 for some time now and the only disadvantage so far is the dynamic files library. Since Lookout 4.5 supports ActiveX platform, I thought it would be possible to import a graphic file created in, let say, Microsoft Visual Basic. There is a nice dynamic graphic library available (from Software Toolbox) with ActiveX base. I can import the dynamic file into Microsoft VB and it looks great! Dynamic movements are like I would like to get on inside my Lookout project.
But now one one of forums for Lookout 4.5 I read that it is not as straight-forward to import ActiveX. It would have to be "wrapped" within special application so that Lookout would accept it. And, yet on another forum there is an explanation how to create an ActiveX object within Lookout through selecting a tab for ActiveX. But I don't seem to have this in my program. The only acceptable type of object is (by default) this group of different objects in library. But no ActiveX in it, at least I don't see it. I have to admit that I am not a programmer, only SCADA user. So writing special programs for this would probably be out of my range.
Could someone please explain this once for me if there is a way to import dynamic graphic ActiveX or not? And if there is one, please send me link to check it. I don't want to spend days trying to figure out walkaround if it would not help.
Thank you so much for all inputs.
Darek
(6,073 Views)
When you create object, you can select the activeX object, like the attached pic. All registered activeX object can be inserted into Lookout, but there is some limitations. See this article.
http://digital.ni.com/softlib.nsf/websearch/26166A48F59026A986256BBC0053AAFD?opendocument&node=13207...
The Lookout Object Development Toolkit can help you to develop your own object for Lookout.
Ryan Shi
(6,046 Views)
Thank you for the info, Ryan. I will look into this method. Also, I asked a developer of graphic files for HMIs (Software Toolbox) to try if it would be possible to synch dynamic ActiveX objects for Lookout application. They already developed special software for Modbus and few  other protocols. Their bmp graphics links with Lookout beautifully. ActiveX files have not been tested yet. They promised to work on the demo of Lookout to try to develop something for other users so that maybe it would permit  importing ActiveX objects when their software is purchased. I will post any new info regarding this matter.
Darek S.
(6,036 Views)
