Lookout
Lookout 5.0
Will Lookout 5.0 run on Windows 7 Platform?
Message 1 of 8
(10,211 Views)
no, 5.x will only run on XP.
Message 2 of 8
(10,209 Views)
Accepted by Blaken
If the system has Windows 7 Pro it includes XP Mode.  Lookout can be run under XP Mode.  Should work for most processes, but performance may become an issue for larger systems.  Also consider VMWare for virtualizing XP.
Mike
Forshock - Consult.Develop.Solve.
Message 3 of 8
(10,177 Views)
I have a old system , it's run lookout 5.0
But PC broken
I know , lookout 5.0 only run winxp
Do you know how can I transfer old program
Message 4 of 8
(5,326 Views)
@mayjimmy Can you clarify your question. I read it in 2 ways:
1. You want to move the Lookout application to another PC running Windows XP.
2. You want to move to a PC running Windows 10.
Message 5 of 8
(5,317 Views)
You could fix it, recover an image/backup.
Lookout 5 processes typically convert to 6.x, 6.7 without issue.
You could play the extortion fee NI charges for antiquated, unsupported software and use Windows 10 with relative success. Like using a newspaper to plug a hole on a fish tank.
Copy the process files, any external drivers & graphics to new machine.
Message 6 of 8
(5,314 Views)
I want to move OLD LOOKOUT5.0 PROGRAM  to a PC running Windows 10.
Message 7 of 8
(5,264 Views)
You should truly research alternatives. For the price of the upgrade and the fact NI is charging a ridiculous upgrade fee for unsupported software.
How intricate is the process? Io, special/proprietary drivers, Pid &  control logic within the process,  etc.
Message 8 of 8
(5,255 Views)
