MATRIXx
Using Matrix with SMUs
Has anyone used a switch/matrix with an SMU. We are looking to use only the sense (no guarding).
Any experiences anyone can share?
(7,423 Views)
This is fairly common with SMUs and DMMs to help with any voltage drop between the instrument and DUT. The two tutorials below show how to configure a 4-wire measurement through a switch and how to minimize any errors introduced by the switch.
Understanding Switch Topologies
Removing Thermal Offset Errors from Contact, Switch, and Relay Resistance Measurements Tutorial
Also, consider posting your question on either "Digital Multimeters (DMMs) and Precision DC Sources" or "Switch Hardware and Software". Those forums are monitored by the same group of engineers who support PXI as opposed to the MATRIXx tools. If you have specific questions about wiring, programming, or grounding 4-wire measurements that forum will be more responsive to your questions.
Jake Harnack
Product Marketing - Precision DC
Jake H | Product Manager
(7,376 Views)
