MATRIXx
***W*** No symbol(s) found
What does this warning mean?
load file = "mysbdfile.sbd"
`load' file = "c:\mysbdfile.sbd"
mysbdfile.sbd is a Signal Build Model with User Code Blocks.
Andreas
(13,230 Views)
Hi Andreas,
This warning has come up before when there are no variables in Xmath. Is this the case with you?
(13,214 Views)
Well, there was no variables in Xmath, but trying to define some and calling the same command (open file = ...) doesn't seem to affect it, I still get this warning. It seems to depend on which file I choose to load, but I can't figure out what this warning really means...
It might depend on which function name the User Code Block calls in some way...
Andreas
(13,211 Views)
Accepted by andreasse
I'll post the answer I've got from the support, if someone else also would like to know
> The "*** W *** No symbols(s) found" is just a warning since the open and save command expect variables to be in the file.
> The warning is to let you know that nothing was changed in Xmath.
> To remove the warning, add {build} to the end of the open or load command to indicate you only want to load SystemBuild data.
Andreas
(13,203 Views)
