Machine Vision
千兆以太网相机初始化异常缓慢
使用BASLER千兆以太网相机,在相机自带软件中使用正常,但在MAX中打开相机就非常缓慢了,通常需要20秒左右,其中一个500万像素的相机竟然用了200秒才完成打开。程序中使用“IMAQdx Open Cameral Vi”时与MAX的情况一致。之后使用相机拍摄是正常的,帧频也没有明显损失。这是什么问题呢?请多多指教。谢谢!
(2,909 Views)
English Translation:
Gigabit Ethernet camera initialization is unusually slow. Using the BASLER Gigabit Ethernet cameras, the camera comes with software, but is very slow to turn on the camera in MAX, usually takes about 20 seconds, one of the 5MP camera actually used 200 seconds to complete opens. MAX is used in the program "IMAQdx Open Cameral Vi". After using the camera is normal, the frame rate and no significant loss. Is this a problem? Thank you!
Have you tried turning off any Firewalls to see if this helps?
你试图关闭Windows防火墙来看看这有助于吗?
Chris Walker
Certified Labview Developer
(2,900 Views)
请尝试关闭相机的 DHCP功能,改用静态IP。
(2,896 Views)
