08-03-2017 04:24 PM
Hi
The project, I am working on, is sensitive to angle values. Why the angle values varies for every iteration? How to stabilize these values?
08-03-2017 10:19 PM
image are in pixel format for angle algorithm should find appropriate pixels for example using edge algorithm is one that most of these algorithm use statistical function like averaging or median so they are so sensitive for any change of value in any pixels and could make such problem you indicate
for prevent it use threshold value to show change in angle or make code that recalculate angle just anytime that some regardable thing change in image
08-04-2017 12:32 PM
Thank you for the response. I am working on nanoscale so any change in 0.001-degree cause problem. Are there any modifications do I have to do in Vision assistant to avoid it? I am using threshold as well as filters to sharpen and smoothing the image.
