05-11-2019 10:02 AM
When creating a new custom inspection interface in Vision Builder does anyone know how to automatically populate a table with all step results?
05-14-2019 10:00 AM
Hi Telecentric,
The automatically populating the table feature is only available with the default inspection interface. However, it is possible to implement in a similar table in a custom inspection interface.
This forum post has a discussion on how the user implemented such a table
05-14-2019 11:23 AM
The problem is to dynamically handle getting all the results as more steps are added as like int the default inspection interface.
05-15-2019 01:47 PM
Hi Telecentric,
As Brad mentioned in the previous post, there isn't an easy way to do this dynamically. However, he included recommendations under step "B" from this forum that you should consider (I linked to that post).
It will also help users provide recommendations if you elaborate on why you want to do this dynamically. Images of your current situation are usually helpful.
Best,
Ben
Technical Support Engineer
