Machine Vision
Best reasonable machine vision camera?
You are accessing it currently via their drivers and the DirectShow interface. You must have installed their drivers as well. While it looks like they translated most of their features into their DirectShow interface, they can't put them all since the interface is limited. If this meets your needs, you might be in good shape. If you need something like triggering, it won't show up in that interface, for instance.
It does look like the camera is also showing up as a GigE Vision camera as well (MAX puts it under the Network Devices section). You could try accessing the camera via that interface and see how well it works. This would use the camera's XML file and hopefully would have all the features exposed.
Message 21 of 25
(2,544 Views)
a good option is to use the camera MIcrosoft HD 500, besides having good resolution has coorector white and its parameters can be made through softaware http://www.microsoft.com/es-es/moviles/accesorio/hd-500/
Message 22 of 25
(2,399 Views)
Emergent Vision will display 50 MP 10 GigE Cameras with Cmos Sensor technology. They use Sony Imx250, Imx252, Imx253, Imx255 that enhances performance of their high speed 50 Megapixels 10 GigE cameras.
You can visit their website at www.emergentvisiontec.com, they have the gadget you are searching for.
I hope it works out for you.
Message 24 of 25
(1,299 Views)
Hi visionmotion!
Maybe this vision sensor could be something for you? It doesn't only serve as a camera, but can also be programmed by you yourself so you can customize it exactly to fit your requirements:
https://youtu.be/FBiAqq-By1E
Message 25 of 25
(935 Views)
