Machine Vision
Camera output mode problem - some gray level values are never assigned?
Camera - basler line scan camera spl 4096-140km
Frame grabbler - PCIe-1433
When acquiring at 12-bit mode, some gray level values are never assigned? An example is shown below. Card and camera were set to run in 12-bit mode. Test image looks normal. I suspected the IMAQ write to tiff vi is the problem but I am not sure.
(3,030 Views)
Are you reading this in Matlab then you need to invert the Tiff endian type. This is a comon problem between Matlab and LabVIEW. What do you get when you try a histogram in LabVIEW?
(2,990 Views)
Hi, could you elaborate more? The image was subtracted of 2^15.
(2,979 Views)
