08-12-2013 11:27 AM
I am using an NI 1744 with NI Vision Builder AI 2011. When I am in the inspection interface, the camera will acquire and display an image. When I switch over to the configuration interface and try to set up the acquire image step, I get error -1073774588: undefined error. I sometimes also get error -1074396159: not enough memory.
Solved! Go to Solution.
08-13-2013 03:10 PM
Hi gskt,
Try checking out this forum post in regards to the memory error. The unknown error might be related to this as well. Although there is not much information out there about this error, it appears that it is related to VBAI 2011 specifically. You might try upgrading to 2012.
08-14-2013 09:28 AM
Thanks for your repply Burrito.
The problem was sloved and both errors went away after I formated the camera and reinstalled the software back on the camera.
