Machine Vision
Cast U64 RGB image to U32 RGB image
Hi All ,
I am trying to cast a U64 RGB image into a U32 RGB image. I have attached the VI and a sample image(U64 RGB).
I am facing 2 issues:
1) I am unable to see the U64 RGB image in the image indicator, though I can read the pixel values. Why is this happening?
2) I am unable to cast it to a U32 RGB image.
Thank you for the help.
Aveo
(3,104 Views)
could you resend your file in lower version for example 2014
(3,057 Views)
Hi
I have attached a 2014 version of the program.
Aveo
(3,051 Views)
Accepted by aveo
I use this method check and see if it could solve your problem
unfortunately vision could not show u64 image directly and it is bug
(3,045 Views)
Thank you for the reply. I ran it. It works, however the colors appear slightly changed from the actual image. but its working. Thanks a lot.
How can I make NI take a note of this issue?
Aveo
(3,032 Views)
