07-24-2012 05:43 AM
07-25-2012 09:37 AM - edited 07-25-2012 09:38 AM
Ok, so that was a bit of a wall-o-text, let me try and rephrase the question...
In the example ...Vision/3. Applications/Golden Template Inspection Example.vi:
Why does it stop finding the defects when I connect the scale wires from the pattern match?
I want to be able to inspect things that are slightly larger or slightly smaller than the template.
07-26-2012 08:10 AM
Got this sorted in the end (via a call to support) so am leaving a note for anyone in the future that has this problem:
The normal pattern match VI does not ouput scale information.
You need to use GEOMETRIC pattern matching to get the scale information.
