Machine Vision
Geometric Pattern Match - algorithm
Hello All,
I have a program for geometric pattern matching (see attached picture for vi's I have used) and I was looking at an example from LabVIEW examples as well. Can anyone please help me find out which algorithm this vi's are using to perform geometric pattern match?
I understand it may be hard to find exact algorithm since LabVIEW has their own codes but I just want to find out algorithm/theoretical process that is close to what this vi's are using so I can read and understand the idea behind the work/pattern matching these vi's are performing.
(447 Views)
Most of algorithms inside of NI Vision are "closed", but some information is available in Concepts Manual:
Official NI PDF in the attachment, read it from page 254.
(414 Views)
Thank you for the information. I will read through it.
(401 Views)
