06-12-2019 11:14 AM
06-13-2019 01:01 PM
Hi Fame_K,
Could you elaborate on what you mean that the camera identifies the nut many time? What are you expecting to see from the servo, and what are you seeing when you mean nothing works?
Thank you,
Joseph Paul
06-13-2019 09:50 PM
Hello)
I mean, when identifying an object, the camera constantly fixes its changing coordinates and because of this, a 1-0-1-0-1-0 signal is transmitted to the servo, instead of just 1. How can I fix the coordinates of the found object only once?)
