Machine Vision
HELP WITH machine vision system!!!
(2,060 Views)
Hi Fame_K,
Could you elaborate on what you mean that the camera identifies the nut many time? What are you expecting to see from the servo, and what are you seeing when you mean nothing works?
Thank you,
Joseph Paul
(2,015 Views)
Hello)
I mean, when identifying an object, the camera constantly fixes its changing coordinates and because of this, a 1-0-1-0-1-0 signal is transmitted to the servo, instead of just 1. How can I fix the coordinates of the found object only once?)
(2,008 Views)
