08-24-2009 03:46 PM
Solved! Go to Solution.
08-24-2009 04:11 PM
If you installed the vision drivers with 2009, you will need to uninstall them and reinstall the 8.6 version. Specifically, the Vision Acquisition drivers. I don't think the base LV 2009 installation will make a difference.
I installed LV 2009 and Vision module on my system, but I didn't install any of the drivers. I haven't had any problems with compiled executables yet...
Worst case, also uninstall the 2009 Vision module and reinstall the 8.6 Vision.
Bruce
08-24-2009 04:41 PM
Bruce,
Are you using NI Vision Runtime and/or NI Vision Acquisition?
08-24-2009 07:06 PM
Thank you for your uninstall suggestion, but we put so much work into getting the 2009 drivers installed I didn't want to back them off (we have a LOT of machines on our line)
I was able to resolve the issues on the floor. It turns out that if you include IMAQ in the installer for 2009 it fixes the ‘resource not found’ and missing vi problems, but you get no images in your applications. If you then download the 975mb IMAQ Vision Acquisition it then gives you an image. This installer for IMAQ Acquisition gives you 27 more applications than the former (which installed 88) and somewhere in the 27 is the magic that made it all work. I am fairly pleased that it is all working, although it was quite harrowing. I am sorry if I sounded too frustrated above, I really do like NIs products and am committed to them.
Nick K
08-24-2009 07:08 PM
I do use those, but I did not upgrade them (as far as I know). I ran the Vision installation, but I did not install anything off the drivers DVD.
I was able to build an exe and send it to a customer, and they were able to run it.
Thus my advice to uninstall the 2009 drivers and reinstall the 8.6 drivers.
Bruce
08-24-2009 07:28 PM
I didn't want to leave thie thread before saying the following...
With the 2009 upgrade I see two issues:
08-25-2009 02:43 AM
08-25-2009 10:00 AM
FooFooFoo wrote:I didn't want to leave thie thread before saying the following...
Thank you for your concern, I look forward to an easier upgrade path and love the fact that it will be one year from now.
- if you install 2009 drivers on your PC you can no longer go into LV 8.6 and make applications that work on 8.6 Vision Runtime and Vision Acquisition.
- If you are in 8.6 and include IMAQ in your installer to rectify this issue it does not include all the parts of 2009 necessary to make your application work, you must download install the full 975mb 2009 Imaq Acquisition for your 8.6 application to work.
Observation #1 above seems correct. If you develop an application with the 2009 versions of Vision and Vision Acquisition Software, then any machine where you want to run the application also needs the 2009 versions (or newer).
Observation #2 above does not seem like correct behavior, and I would like to look into this further for you. We would expect your application to work if it was developed and distributed with the 2009 versions of the Vision Acquisition Software drivers included in the installer.
My test scenario will include LabVIEW 8.6, Vision 2009, and Vision Acquisition Software 2009. I plan to build an application using NI-IMAQ and Vision (including an installer with NI-IMAQ and the Vision Run-Time Engine included) and then install that application on another clean machine.
Are you only using NI-IMAQ, or do you use NI-IMAQdx in the application as well? If you have any other feedback or suggestions for my test, just let me know and I'll change things up. Either way, I'll reply back with my results.
Jesse
08-25-2009 10:09 AM
08-25-2009 10:10 AM
