Machine Vision
How can I get an image back to labview from opencv dll code?
Hello!
Can you explain, what is threshold1, threshold2 and kernel_size?
Message 11 of 15
(1,636 Views)
Did you check the link earlier mentioned?
Those parameters define the threshold values of hysteris process(which is part of Canny Edge Detection)
For ref adding here: http://docs.opencv.org/2.4/modules/imgproc/doc/feature_detection.html?highlight=canny#canny
Read more here:https://en.wikipedia.org/wiki/Canny_edge_detector
uday
Message 12 of 15
(1,630 Views)
Thank you, I have understood it with your help!
Message 13 of 15
(1,623 Views)
It seems that LabVIEW can correctly pass color image to opencv via 2d uint32 array pointer. But it doesn't work when you pass a color image from opencv to LabVIEW。At LabVIEW side,it just shows what you pass out to opencv even if it's been changed a lot. In my experiment, it is true. Maybe there is something wrong in my code or some particular reasons I will never know.
My environment:
LabVIEW 2017 64bit trail,
OpenCV 4.1.2,
windows 10 pro 64bit.
Message 14 of 15
(1,132 Views)
This have solved my encountering issue. Thanks you so much.
Hsing-Yu Chen
Message 15 of 15
(1,011 Views)
