Machine Vision
How do I delete access-denied files in C:\Program Files\National Instruments directory
I guess I accidentally erased some files in the National Instruments folder on a WindowsXP computer.   I am trying to install LV RTE 8.2 and NI-DAQ 8.5 but both got denied(cancelled).
Is there any way to get a clean start by deleting the entire National Instruments folder from my C drive?
hellolv
(4,224 Views)
Are you encountering any installation errors? If so, what is the error message?
If you are experiencing trouble with your installation, you should probably contact NI directly and an applications engineer can assist you in further detail.
Emilie K. | National Instruments
(4,195 Views)
Good day team,
Please i am facing a challenge in delete all national instruments folder directory. the subfolders MAX and Shared wouldn't get deleted. Kindly assist me solve this issue ASAP
(2,181 Views)
(You probably should have started a new thread instead of appending to a 15 year of thread about windows XP.)
What installations originally created these folders? Did you uninstall all products first? How are you trying to delete these folders and what kind of errors do you get?
What is your OS? Do you have admin privileges?
What problem are you trying to solve by deleting? Are you talking about the 32bit or 64bit NI folders?
(2,177 Views)
Hi thanks for your reply. I guess the installation that created these files is the first one when i was attempting to install LabVIEW by just using the NI package manager. I think i tried to uninstall all product by using IOBIT software but apparently those folders remained on my disk C. my operating system used to be Windows 10 but now i got upgraded to Windows 11 and i think i have admi privileges. By deleting all these files, i want to start afresh. i want to install LabVIEW 2019. Nevertheless, i have tried to install LabVIEW 2019 anyway but i keep getting an error (
An error occurred while installing a package: ni-mssilverlight (5.1.8.49152-0+f0)
Additional error information:
An error occurred in OnTransactionStep for transaction type 'install'.)
Kindly assist me!
(2,166 Views)
No current version of LabVIEW is officially supported under windows 11. Silverlight support has been ended by Microsoft.
Sorry, I am still using windows 10, so I cannot give further advice.
(2,162 Views)
I encountered almost the same problem, but I am trying to install it on Windows 10.
An error ocurred while removing a package: ni-mssilverlight (5.1.8.49152-O+f0)
An error occurred in OnTransactionStep for transaction type 'removel'.
By chance, did you find a solution?
(798 Views)
