11-18-2018 11:49 PM
I am using count object 2 function to detect non transparent (Black) particles and that is working fine. Now I want to detect Transparent (Glass) particles from the same Image.
Glass bottle is filled by water and mix particles are present in the glass bottle.
I also tried to use filter in then used the count object 2 function but it is not working properly.
Please suggest the solution
Any help would be highly appreciated.
11-19-2018 12:43 AM
Can you share images?
11-20-2018 01:15 AM
