Machine Vision
How to grab signed 10-bits images from camera link camera
Dear all,
I have a custom-made camera that outputs signed 10-bits images through camera link grabber card (PCIe-1437).
The issue I met when I try to grab the images on MAX (Measurement and Acquisition Explorer) is the bit assignment in a 16-bits data.
I expect the assignment is as follows,
[+/-] | <- | <- | <- | <- | <- | <- | x | x | x | x | x | x | x | x | x |
However actual assignment was as follows,
1 | 0 | 0 | 0 | 0 | 0 | [+/-] | x | x | x | x | x | x | x | x | x |
Is there any way to fix this issue by changing commands in camera file (*.icd)
H. Yamada
(2,011 Views)
Have You used this when created Your  ".icd "?
Also this link can be useful for You, and this one for more information about "PCIe-1437".
Regards.
(1,974 Views)
Thank you for your reply. Now I tried to create camera file (*.icd) with Camera File Generator (CFG) you recommend.
However, I could not find bit assignments in 16-bits data in CFG
H. Yamada
(1,966 Views)
Here is the link for helping with 16-bit files.
Also check this one, it might be because of Your camera.
Regards.
(1,960 Views)
Thank you for additional links to solve this issue.
I have already solved the bit-assignments on LabVIEW program (software).
Now I would like to find another way to solve this in a hardware (in PCIe-1437).
H. Yamada
(1,935 Views)
Accepted by hidezo
Hi Yamada,
It should be fairly easy to fix this issue on Vision FPGA card like PCIe-1477.
When you program the Vision FPGA you have direct access to assign the pixels in hardware.
You can look at example code "PCIe-1477 Getting Started.lvproj"
But I think it might be overkill if you can do it in software very quickly.
If you have real need to do it in hardware then PCIe-1477 or PCIe1473R can do it as fast as the camera can go.
Thanks - Amit,
Amit Shachaf
(1,907 Views)
