12-02-2010 07:10 AM
IMAQdx seems to search for GigE cameras by periodically (about every second) sending a "Discovery Ping" to 255.255.255.255.
As my vision system does not use any GigE camera (only FireWire) I would like to get rid of these "Discovery Pings".
Is there a recommended way to accomplish this?
Regards, Guenter
12-02-2010 12:15 PM
Hi Guenter,
On Windows there is not currently a simple way to disable GigE Vision support in the installer. However, you can disable the automatic discovery mechanism with the following registry key:
You should be able to save the following as a .reg file and import it:
Eric
12-02-2010 02:27 PM
12-02-2010 03:31 PM
You would lose automatic discovery of GigE Vision cameras. You can still manually discover cameras by running the Discover Ethernet Cameras function/VI.
Eric
12-02-2010 03:40 PM
Ok, Eric. I see, that it works. (No need to wait until tomorrow.)
Thanks, Guenter
03-25-2011 11:32 AM
I have a couple of questions in regard to this.
If use the registry key as described is there a way to manually detect the camera when you are using the Measurement and Automation Explorer?
Is there anyway to restrict the discovery ping to a specific network card? We typically install a second NIC card and use non-routable IP addresses for that NIC and camera and it would be nice to limit the discovery ping to that card.
Later
Walleye
09-24-2018 04:41 AM
Hi Eric,
i cant see the link
09-24-2018 05:10 AM
As this is an old thread I don't know if you can still rely on this information.
However, if a registry key doesn't exist, you can create it ...
