05-14-2012 07:22 AM
when i try to initialize the camera of Baumer TXG04h, it seems to have a red cross in the MAX,and I get the error message: Error 0xBFF6902C Unable to connect to the camera.
Then i used a procilica GE680 instead, but the error occurs still.
and i also check the Ip configuration, I think it is correct.
also, it is strange that everything runs well with the demonstrate program provide by Baumer.
I try to figure out what's going wrong, but after searching NI.COM, I got no answer.there is nothing i can use in Troubleshooting GigE Vision Cameras
Really appriciate for your help!!!!
05-14-2012 07:29 AM
11-06-2012 07:31 PM
It's may be the problem of antivirus software.
I have the same problem before because of ESET NOD32 Antivirus 4,it will be solved when you uninstall the antivirus software rather than stop it.
11-18-2022 05:10 PM
Perhaps you can check this KB.
I have the same issue with a Teledyne Camera.
Unable To Connect To Camera Error 0xBFF6902C - NI
Hope this helps.
