11-20-2015 06:48 AM
Hi
I get the following error when I try to extract all of the frames of an avi file. Error -1074396010 occurred at IMAQ AVI2 Read Frame
I have it in a while loop to execute reading and writing the frames and then save them as .jpegs.
Any insight or help is appreciated.
Solved! Go to Solution.
11-23-2015 04:41 AM
solved it myself. thanks
07-26-2017 01:22 PM
I am having a similar error, how did you end up fixing it?
08-24-2022 10:25 PM
Can you post how you fixed it? Labview is linking to this post
