06-13-2012 08:40 AM
06-13-2012 10:29 AM
For licence issue I always recommend to contact the local support or/and the local sales rep.
On my computer, the licence manager says "never expires" for both VAS and VDM (I have 2011 SP1), from the licence manager you should be able to select VAS and then clic on "Activate" (top left)
Hope this helps
Epictetus
06-14-2012 06:38 AM
06-14-2012 06:52 AM
I think you need different serial number for VAS and VDM, these are different products.
Epictetus
06-14-2012 09:38 AM
Hi TiTou
If am not wrong VAS comes with VDM as seen here http://sine.ni.com/nips/cds/view/p/lang/en/nid/2881
06-14-2012 10:13 AM
06-14-2012 10:24 AM
Hi NV-Mike
Better you can contact your local ni rep as TiTou said early.
06-15-2012 10:44 AM
Hi NV-Mike,
Your best bet will be to get in touch with either your local NI representative, or to call in and speak to one of our Applications Engineers. Licensing is sort of a sensitive thing, so we obviously discourage posting serial numbers etc on the forums. Give us a call at 800-531-5066 and explain the situation and you should be routed through to someone that can help you.
