Machine Vision
IMAQdx Open Camera.vi very slow
Doc,
This is correct and expected behavior. LabVIEW will search the system path for DLLs and find it. If it cannot find the DLL, it would not load.
Again, I'd need to see some simple VI that can reproduce this.
Eric
Message 11 of 14
(1,566 Views)
I am re-installing ni-imaqdx... the behavior is too strange. Even if I just make open - close example, sometimes it is fast, sometimes very slow.
I will then open the "grab" example from labview, then will open my project, then will save it and check if it solved the problem.
If I still the same after re-installation, I will tell you
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
Message 12 of 14
(1,557 Views)
Hi Eric,
I re-installed all vision components and the same problem still occurs .... but I found why.
If I put the "IMAQdx Open Camera.vi" in a timed loop with a priority not set to -1, then the time to open the camera is 25 seconds. Check the attached vi to see what I mean
I don't know why... I will leave the priority to -1...
Doc-Doc
Message 13 of 14
(1,540 Views)
Accepted by topic author DOC-doc
Hi Eric,
I also noticed that the same applies if the VI priority is set above normal priority.
Doc-Doc
Message 14 of 14
(1,538 Views)
