11-01-2012 10:42 PM
Hello all,
THis is the third time I have installed Vision tools 2010 where IMAQdx did not install and I have had to manually install the missing parts. Anyone had this problem? Is there a fix for this? The software is activated so this is not the issue.
Thanx,
11-02-2012 03:04 AM
hi i had this problem before but after activating the software, got all the functions http://digital.ni.com/public.nsf/allkb/A451D3CCBB740716862578FC004DB392.
Anyhow try updated version.
11-02-2012 01:14 PM
Greetings,
When you say that IMAQdx did not install, do you mean that the install failed or errored out in some way? Or do you mean that the installation just did not happen and you could not see the software on MAX?
And manually install the missing parts, would you mean that you later installed IMAQdx alone and it worked fine?
Finally, when in the process did you activate the software and what was the installation procedure; as in, what order did you install your software in?
Would you happen to be using LabVIEW or simply using MAX? If so, what version of LabVIEW? Finally, would you happen to have some sort of antivirus system that may be blocking some of the installations, particularly those that automatically connect to the internet?
I wish you a great day!
Simon P.
11-02-2012 01:22 PM
I am using windows 7 64 bit LabVIEW 2010 32 bit and VIsion 2010, IMAQdx simply will not install on a Windows 7 64bit. Originally I was using XP 32 bit and it will install fine from the same distrubution DVDs (DS2). I have to spent an hour or more chasing down all the things needed for IMAQdx and install them manually. I have had done this 2 times on other Windows 7 64 bit machins that are now working fin and I use frequently. All software is activated.
Thanx,
Karl
