07-15-2016 01:40 PM - edited 07-15-2016 01:42 PM
I have an Allied Vision Manta_G-201C-30 camera connected via ethernet to a PXI-8231 card in my PXI chassis. I think I have all of the correct software installed, but it is complaining that it the network interface doesn't support "high performance acquisition."
I did find one reference to the error code in the knowledge base (http://digital.ni.com/public.nsf/websearch/8BD2C327BA3378B786257949006E64EE?opendocument&Submitted&&...), but the solution to that issue was to use a separate ethernet card which I am already doing.
Any thoughts?
07-15-2016 02:15 PM
"However, only certain hardware revisions of the PXI-8231 are capable of preventing this error." From the same link you provided and the same hardware you are using.
-Did you try following the steps in these: http://www.ni.com/product-documentation/5846/en/
-Enabled Jumbo packets?
-Region of interest in 0,0,1,1 or you were trying with these settings? with other ROI did it work?
07-15-2016 02:20 PM
I am not sure how to enable Jumbo packets, since the link describes doing this via Windows but my ethernet card is on a PXI RT chassis. I did try reducing the packet size but this did not help. I also tried setting the Region of Interest to 0,0,1,1 and 0,0,100,100 with the same error.
07-15-2016 02:34 PM
07-16-2016 06:46 PM
