07-29-2012 12:29 PM
I am capturing images from a conveyor using a photo switch wired directly to the camera. The problem is the image capture rate is not fast enough. The attached basic capture logic is running at about 350 ms but I am only getting every second or third image. I am using the following equipment:
-Prosilica GC750 GigE camera.
-SMC 8508T Switch.
-Intel PCI Pro/1000 Card.
-Labview 8.6
-Dell Inspiron 530 with Intel Core 2 processor Q6600, 2 Gigs Ram.
When I run Measurement & Automation Pro "Grab" every trigger is captured. I have configured the network interface for Jumbo frames. Is there something I have forgotten or is this possibly the limitation of the equipment.
Thanks for the help,
Doug
07-30-2012 03:01 AM - edited 07-30-2012 03:01 AM
open MAX and in the ethernet card of the camera configure the packet size to 9000 (same size as intel card JFrames).
Are you getting every image if using MAX, I am a bit confused from your post.
Try to use this VI, read help to know how to configure buffers.
I allways use this kind of reading mechanism to get the pictures.
Check your network load and CPU load when grabbing.
How do you know you are getting every third frame ?
07-31-2012 07:51 AM
I had already set the packet size for 9000, but I will try this approach. Thanks for the reply.
Doug
