Machine Vision
Image format for Stereo Vision.vi
Hello!
In Stereo Vision Example.vi, the number of disparity is computed by IMAQ Get Maximum Disparity VI, I think the maximum depth is set by user. I use two Basler acA cameras with 1.86m height above the ground. After many times calibration, I got a result, but not very good. I used a point grid that distance between points is 2cm.
I post this, who can tell me, how to calibrate cameras right?
CLD
CAU
Message 11 of 18
(2,126 Views)
second part
CLD
CAU
Message 12 of 18
(2,123 Views)
Dear lizguo_lin,
You can calibrate your cameras using LabView example called Calibrate Stereo Vision System.vi,
with this example you can calibrate and after save the calibration for future use.
Andrei B.
Message 13 of 18
(2,066 Views)
Hello! bocasy
I use Stereo Vision Example.vi to calibrate my two cameras, I search  Calibrate Stereo Vision System.vi through NI example finder, but found nothing.
Can you tell me where is it. Actually Stereo Vision Example can calibrate stereo vision system. I just don`t know how to calibrate my stereo system effectively.
CLD
CAU
Message 14 of 18
(2,051 Views)
Hello lizhuo_lin,
I used the Stereo Vision Example.vi also and run into some setbacks but managed to make it work. The depth of field data it's not 100% consistent with the real data and because of the time I estimated to be needed for solving this  issue I suggest you  to contact the local support so they could get more information about the problem and assist you.On following link: http://www.ni.com/niglobal/ you can find list of our Worldwide Offices.
Andrei B.
Message 15 of 18
(2,024 Views)
Hello! bocasy
Thanks for your kind reply! I contact NI AE, but he can`t solve this problem. So I post there.
Are you a staff of NI company? LabVIEW 2013 is release at 8.2, and you know the new example of LabVIEW 2013 called calibrate stereo vision system at 8.1! Ha Ha!
I try a little bit of LabVIEW 2013 and VDM 2013, there is still some mistake in the example, and the explanation in calibrate stereo vision system.vi is not good enough, so it`s no wonder you can`t get good calibration.
CLD
CAU
Message 16 of 18
(2,003 Views)
Hello lizhuo_lin,
What you are facing, indeed is an unexpected behavior.
My advise is to contact your local NI branch and validate this behavior. Afterwards it will be a lot easier to escalate it to the R&D or people that will be able to solve it in the future versions.
Andrei B.
Message 17 of 18
(1,973 Views)
Hello! bocasy
Thanks for your reply!
I already contact NI China, but they also cann`t calibrate the stereo vision system.
LabVIEW is released and Stereo vision model is not updated. It seems that NI is very confident with this model.
And I found the way to calibrate the stereo vision system. I put it in a new post as followed
http://forums.ni.com/t5/Machine-Vision/How-to-calibrate-a-stereo-vision-system-with-tow-cameras/td-p...
CLD
CAU
Message 18 of 18
(1,960 Views)
