Machine Vision
Image processing with one camera
Hello team, I'm new to the forum and LabVIEW world. I got in college courses LabVIEW programming where we learn the basics, and I and my team were tasked with a USB camera to make image analysis recognizing colors and shapes of the object. So please if you can give some initial guidance from where to start? Thank you!
(3,686 Views)
Hi Matija95,
I would check to see if your school has Vision Acquisition and Vision Development Module licenses in their academic agreement. This KB gives info about what both of these do. One you have these installed and activated, there are a plethora of examples to get you started.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(3,681 Views)
Thank you for your reply, We have the ability to use Visio modules we have student license, I set the vision assistant, and we have available for use NI myRIO or NI myDAQ, I got a webcam Logitech C270 gave to be with her work image processing?
(3,659 Views)
(3,656 Views)
shape.pngalso for shape you can use this vi
all will be possible if your have toolkit of vision and motion
(3,654 Views)
colleagues,
I managed to make a VI that takes my picture, now I'm interested in whether anyone can check if everything is fine? And now it remains to make the Vision Assistant adjust the parameters that we like to detect the color and shape of the object. VI is attached for verification
(3,642 Views)
what you did is not correct indeed bellow image show what you want in VS  to use so work with them
also check the links that I send you in previous post it will help you
and do not forget for color analyse you never should spread color channels
also intensity matching is irrelevant for your work
(3,638 Views)
