Machine Vision
LabVIEW doesn't detect USB 3.0 Basler Cameras
Hi EveryOne,
im using a basler USB 3.0 Cameras but LabVIEW Doesn't detect it
can anyone help me ?
thanks
Message 1 of 8
(5,480 Views)
Accepted by mon3am
Do you have Vision Acquisition installed? http://www.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,n8:13.79.7820,ssnav:n...
Can you see and use the camera in NI-MAX?
Message 2 of 8
(5,455 Views)
Accepted by mon3am
Hi rrobe,
the cameras was using Pylon basler Driver .
i changed it using MAX
thanks
Message 3 of 8
(5,320 Views)
please let me know how to switched from the pylon drivers to MAX. The Basler camera is visible in NI MAX, but the Labview program cannot detect it.
Thanks.
Message 4 of 8
(2,332 Views)
Look at the attached image in the post above yours which shows how to change the driver.
-AK2DM
Message 5 of 8
(2,326 Views)
Oh, got it. Thanks a lot.
Message 6 of 8
(2,317 Views)
MAX indicates that I should change to NI-IMAQdx, but I don't get the option.
In the past I have used this camera in LabVIEW, but I'm not completely sure if it was on this computer, or my previous one.
Message 7 of 8
(232 Views)
I found another topic with the same issue I have (Windows 11 related).  This can be discarded.
Message 8 of 8
(228 Views)
