04-21-2016 07:27 AM
It's an Insight Cognex camera. now i try to use telnet commands to see if it's working. thank you!
04-22-2016 06:45 AM
HI i connected Labview with Cognex using .net .
but the cognex display image takes so much time .
04-22-2016 07:43 AM
can you elaborate on this?
what takes time? i have used this before and its works in real time for me. is it not the inspection processing time that is long?
05-17-2016 08:43 AM
Hello, you can insert code vi Please....
Thank you very much.
10-12-2016 07:18 PM
I am trying this too ..
I would like to have labview communicate with : http://www.cognex.com/products/machine-vision/in-sight-5000-industrial-vision-systems/
If you have done it, and can share the VI, that'd help me get started.
Thanks.
10-13-2016 02:05 AM
Sorry i dont have the vi anymore, but there are two ways of doing it.
either buying the Sdk or using the native mode commands, the sdk allows you to acces all the features and get the image and spreadsheet into labview, native mode just allows you to pass data to and from the spreadsheet and change jobs.
i can supply the sdk, get in touch if you need it.
10-29-2016 05:19 PM
Sorta new on here , how do i get in touch with you? I can get the SDK and take a look at it (to see if its useful)
10-29-2016 07:17 PM
Have a look here: http://www.cognex.com/support/downloads/File.aspx?d=3127
you may need a license to use it though
10-29-2016 07:19 PM - edited 10-29-2016 07:20 PM
I know of that.. if I had the licence, would I be here?
Thanks anyway.
10-30-2016 03:04 AM
Its €1200 if you want a copy
