Machine Vision
Logitech webcam C920 is supported?
Hi,i'm a new bird for labview.
I try to use webcam to acuqire photo.But it is always show me timeout error.
No matter i install logitech driver or delete logitech driver.
C920 is supported ?
I searched it,I think C920 might be ok.
Who can help me?
(4,537 Views)
Thanks,i fixed it
(4,519 Views)
just increase timeout
by the way any time that you find the answer you should explain it here for other
in this case if any other have same problem you will be help him
(4,497 Views)
Accepted by 0zhang9
Yes,Thanks for your reminder.
My solution is Increase timeout.
(4,495 Views)
Increase timeout time is a simple way to slove the problem
(4,450 Views)
yes I know this is simple thing and also I mentioned about it in my last post but the reason that i want auther to post full answer is that , may be some body do not know about it and waste many time to find the problem of this issue
(4,430 Views)
