Machine Vision
Morphology black picture out
i am facing a curius problem with the output image from morphology. In vision assistant i see clear the result. Now i receive always black picture.
Tipp; after the Cast Image the picture is correct.
What i missed? Could somebody helps?
Thanks!
(2,429 Views)
Accepted by panov
You used binary morphology, so you get a binary image back.  The values are only 0 and 1, so you need to use the Binary palette to display it.  Right click on your image display and select Palette -> Binary.
If you were trying to do gray scale morphology, that is a different VI.
Bruce
Bruce Ammons
Ammons Engineering
(2,419 Views)
Smiley Happy
Thank you!
(2,394 Views)
