01-27-2019 03:48 PM
Dear Members,
I have a image processing project which would be very important for me to finish. However, I do not find NI-IMAQdx option in the Vision and Motion toolbar (I attached a picture about it). I use LabView 2014 (32-bit) and I also installed NI Vision Acquisition Software 18.5 which I thought will solve my problem but it didn't. I also checked the licenses and all of them are activated.
Another problem which I believe is connected to the above mentioned one is that when I want to open a camera with Vision Acquisition, LabView does not find some VI-s on the computer and therefore it's not working. I attached some pictures about it.
Does anyone has any idea what should I do to make NI-IMAQdx to work? I would really appreciate if someone could help me out. Thanking you in advance yor your time and assistance.
vitya
01-27-2019 03:57 PM
Hi Vitya,
The problem is that Vision Acquisition Software (which includes NI-IMAQdx) 18.5 does not have support for LabVIEW 2014. Any VAS release is compatible with the 4 latest major versions of LabVIEW. For 18.5, this means LabVIEW 2018, 2017, 2016, and 2015. You'll need either a newer version of LabVIEW, or an older version of VAS (<=17.5).
Hope this helps,
Katie
01-28-2019 06:11 AM - last edited on 11-19-2024 10:11 AM by Content Cleaner
Hi Vitya,
For future reference, you can find the compatibility chart here: https://www.ni.com/en/support/documentation/compatibility/17/vision-acquisition-software-and-labview...
Also, you can find info about LabVIEW support in the Vision Acquisition Software's readme file
01-28-2019 12:32 PM - edited 01-28-2019 12:33 PM
Thank you so much for both of your quick response and help.
