Machine Vision
Need help on passing an image from sub vi to main
Hi all,
I'm having trouble setting up a Control refnum. here's what I'm doing and what isn't happening.
I have an acquisition loop that runs continuously and puts images into a queue. From there a sub vi takes the next image and does some processing. I want to display the resulting image in the front panel of my main vi.
Having read the advice here on this subject I understand that I have to put a Control Refnum on the sub vi. When I do that I then go to configure it as an image control and this is where I'm stuck. Right clicking on the front panel and going through Select VI Server Class >> Generic>> GObject>>Control, on the front panel there's no image control mentioned. When I do this from the block diagram ImageControl is listed but I can't select it. I click but nothing happens. Am I missing something here?
BTW: LabVIEW 2015.
(2,893 Views)
By the way, "Image" refnum holds a reference to the memory where the pixel data is temporarily stored. This memory could be overwritten if other data comes in before you display the data on the front panel. Putting the image refnum into queue does not allow you to save the image pixel data into the queue.
I think you can right click the Image Control and create new refnum.
(2,814 Views)
I appreciate the reply but I don't understand it. The image queuing is working fine - it's just a LabVIEW example I've tailored for my needs. My issue is with creating a Control Refnum for moving an image from sub to main vi.
I have created an image control from the sub vi image and dropped it into the main vi block diagram. Right clicking doesn't offer me a way to create a new refnum. Attaching a picture so you can tell me if I've misunderstood.
(2,781 Views)
Let's bump this up with some more info.
This Knowledge Base article says "Select the appropriate VI Server Class based on the type of control in the main VI. Right-click the Control Refnum and select Select VI Server Class >> Generic >> GObject >> Control >> [select type of control]"
When I try that it won't select Image Control. What am I doing wrong? Doe sit matter that I'm using LV 2015?
(2,737 Views)
Create Generic Object Control Refnum and then use Variant to Data Conversion with image data type inside subvi.
uday
(2,721 Views)
Accepted by another_novice
For some reason, you are not allowed to make a control out of an image reference.
In that case, what I do is that I store the image to a global variable and read that same variable on my GUI.vi
(2,707 Views)
A Global did the job. I'd always been advised to avoid using Globals, so this was my first time. Worked exactly the way I needed.
(2,646 Views)
