Machine Vision
Problem regarding the transmission of video Through TCP/IP acquired from USB camera
Hi mikhailether,
From LabVIEW, if you go to Tools>Options you'll find a category called VI Server.  What settings do you currently have configured in this category?
Also, is there a specific error number that you received?
Michael B.
Applications Engineer
Message 11 of 18
(1,238 Views)
Dears
please help me. why shown this error
Best Regards,
Abolfazl Ghanbarzadeh
Biomedical Engineering,(MSc)
Message 12 of 18
(1,130 Views)
hello
please help me.why shown this error?
Message 13 of 18
(1,130 Views)
Abolfazl,
Since this is such an old thread, it would be best to open a new one for your issue.
The error messages are telling you that you are missing IMAQ VIs. That installs with our Vision Acquistion Software:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/12892
You should make sure that you download and install IMAQ (and LabVIEW Development Support for IMAQ and your LabVIEW version).
http://digital.ni.com/public.nsf/allkb/DB928F6D5E9D6B97862579A7006B2850
It also looks like you are missing custom sub VIs. If that's the case, then you need to track down those sub VIs and replace them on your block diagram.
Kyle S.
ni.com/support
Message 14 of 18
(1,110 Views)
Thanks so much. Please send me your instructions about error of attach file.
Best Regards,
Message 15 of 18
(1,082 Views)
Abolfazl,
I would recommend following the two options outlined in the error message:
  1. Locate the typedef and point to it and/or fix the errors there.
OR
  1. Right-click and "Disconnect from Typedef"
Kyle S.
ni.com/support
Message 16 of 18
(1,065 Views)
Thank you so much for your kindness.disappeared error message Only by this can to see the server user image on the client systems .But i want to have two-way visual communication, Please guide me or send me your source code
Best Regards,
Message 17 of 18
(1,052 Views)
Abolfazl,
Please create a new thread for your question. We try to stick to one issue per thread.
Kyle S.
ni.com/support
Message 18 of 18
(1,034 Views)
