Machine Vision
Prosilica GE1910 GigE camera not working in Labview
Does anyone know how to fix this error?
Krispiekream
Message 1 of 8
(4,230 Views)
Hi Krispiekream,
The picture you posted is not clear at all. do you mind replacing it and writing down the error so we can see how to solve the problem. Thanks and have a great day.
Esmail Hamdan | Applications Engineering | National Instruments
Message 2 of 8
(4,199 Views)
you can click on the untitled.PNG link to view the picture in bigger scale?
Krispiekream
Message 3 of 8
(4,196 Views)
Do you see the same error if you turn off the Firewall? This might be the reason that your getting this error. If it's the Firewall, you might want to look at this thread.
Message 4 of 8
(4,166 Views)
I have the BROADCOM NETEXTREME 57XX GIGABIT CONTROLLER as my ethernet card.
I have to sent the packet size to be 1500 bytes in order for this camera to work
but my camera manual says that
"To Achieve full camera performance, you should use a Gigabit Ethernet card that supports "Jumbo frames" of at leasta 9Kb Size.
Do you think we have a ethernet card issue?
When I get the camera to work. the CPU usage is around 70-80% and it lead to crashing of my computer.
Krispiekream
Message 5 of 8
(4,153 Views)
You certainly should get a jumbo-frames capable card.
The workload on the CPU is substantially higher without jumbo-frames enabled.
See also: http://forums.ni.com/ni/board/message?board.id=200&message.id=25872&query.id=473583#M25872
Scott
Message 6 of 8
(4,151 Views)
My camera default packet size is 8000 bytes
But I have to set to 1500 bytes in order for it to work.
With that, my CPU work load increases and it crash my computer.
Do I really need to get a new high preformace card? I thought my dell ethernet card is already high performace?
Krispiekream
Message 7 of 8
(4,149 Views)
Dell's definition of "high performance" is with respect to office LAN environments.
Machine vision imaging is a demanding application, and not something one can necessarily expect Dell, HP, or other manufacturers, who are price-pressured by the market, to plan for.
Please see our (Allied Vision Technologies / Prosilica) knowledge-base articles on camera and adapter configuration and optimization:
Single cam config: http://www.alliedvisiontec.com/us/support/knowledge-base.html?tx_nawavtknowledgebase_piList[uid]=5&t...
Troubleshooting GigE Vision installation: http://www.alliedvisiontec.com/us/support/knowledge-base.html?tx_nawavtknowledgebase_piList[uid]=52&...
Optimizing host computer settings: http://www.alliedvisiontec.com/us/support/knowledge-base.html?tx_nawavtknowledgebase_piList[uid]=8&t...
Scott
Message 8 of 8
(4,146 Views)
