Machine Vision
Running Multiple Vision Builder Inspections Simultaneously from Command Prompt
Dear All,
Is it possible to start running multiple VBAI inspections in parallel using command prompt? I know it's possible by just clicking on the vbai files. If so, what's the correct command to do this? Thank you.
The closest I'm using is "C:\Program Files\National Instruments\Vision Builder AI 2015\Vision Builder.exe" \inspect "C:\Users...\Program1.vbai" & "C:\Users...\Program2.vbai". However, it opens program1 in inspection mode and program2 in configuration mode, how to change this so that both are in inspection mode when ran? Thank you.
(738 Views)
By using "C:\Program Files\National Instruments\Vision Builder AI 2015\Vision Builder.exe" \inspect "C:\Users...\Program1.vbai" & "C:\Program Files\National Instruments\Vision Builder AI 2015\Vision Builder.exe" \inspect "C:\Users...\Program2.vbai", I was able to do this. I previously thought the part after & will only execute after program1 stops.
(715 Views)
