03-31-2022 08:13 AM
Hi. I am trying to send images from VBAI to LabView by using shared variables. I used set variables to set current image in corresponding network variable. I am able to read the image from LabView. However, the image is without overlays even though I used IMAQ Merge Overlay function. How can I get images with overlays in LabView from VBAI thanks to shared variables? Thank you in advance.
04-04-2022 12:16 PM
Hey! Came vi
04-05-2022 12:57 AM
Thanks for answering. Snippet of Vi has been attached.
04-05-2022 03:12 AM
Try to put a control screen (Image) and see what's there. And after recording the image, the memory area needs to be cleared.
04-05-2022 03:18 AM
P. S. Unfortunately I couldn't open it vi. I have LabView 2017
04-05-2022 03:29 AM
I saved my VI as previous version. Are you able to open it right now attached VI?
04-05-2022 03:52 AM - edited 04-05-2022 03:57 AM
I think that SV is not the right thing to send images. I would use network streams.
Unfortunately I have no experience with VBAI. In poor LV with Vision I would proceed like this:
An example (LV2020) is attached and also saved for LV2017.
04-05-2022 04:13 AM
Overlays are created in VBAI and sent to LabView by Network Variables. Unfortunately, I have not seen anything like Network Stream in VBAI.
04-05-2022 05:35 AM
I think this solution will work
04-05-2022 06:12 AM
Here is more detail
