07-14-2016 08:58 AM
Hello -
I have Vision Builder 2012 using a remote camera device. When I use the simulate image acquisition step in an inspection on this device, it fails (see first error below). Since the error recommended I put the images in the c:User Images directory on the remote device, I did so. I assumed this meant that directory in the zip file the camera was configured using, but I could easily be wrong. Not only did that not work, but after that if I tried to configure the camera again Vision Builder would crash with the second error below.
I considered that this was a memory error, so I tried reducing the folder to one image with no success. Any suggestions?
Olivia
07-15-2016 05:44 PM
Hi Olivia,
Does the crash now occur everytime you try to configure the camera? If this is the case you may try repair installing Vision Builder.
Kevin K.
Applications Engineer
07-16-2016 05:44 AM
07-18-2016 08:54 AM - edited 07-18-2016 08:57 AM
Hi Kevin,
Yes, the crash occurs every time I try to configure the camera. I followed the instructions you provided for me and it didn't change anything. Is there any way to hard reset the camera? I just want to be able to configure it to a folder that was working correctly before I modified it, but I'm unable to even get far enough to change it back.
Also, I ran Tutorial 1 and the simulate image acquisition step worked. The images for the image acquisition are in the configure folder, which is where I tried to put my images. This is what led to the configure crash, though I don't understand why that broke the software.
Thanks for your help.
Olivia
07-18-2016 08:10 PM
Where are your images on Windows? You need to match the folder hierarchy on Windows and on the target.
07-19-2016 10:33 AM
So, assuming my path on Windows is something like C:\users\path\to\pictures, there would have to be a path users\path\to\pictures in the folder the target is configured with? Does this folder path need to be within a certain directory in the folder?
Also, my main problem now is that I can't configure the target at all anymore without it crashing. I'm worried there's a deeper problem and the camera needs to be reset.
Olivia
07-20-2016 05:47 PM
Hi Olivia,
You mentioned that you are using a "remote camera device". Is this an NI Smart Camera? If so you can reset the camera by following step 3 of this guide. If not, please let us know what kind of camera you are working with.
Kevin K.
