Machine Vision
Store a single image in Vision Acquisition
Could you post a screenshot of your VI? I have an older Version of LV on my private PC an cannot open your attached VI.
Message 11 of 18
(1,478 Views)
Accepted by nisargsolanki
I have lv2014 so I could not open your vi
but for help you
I create vi
this vi use method 1
also image name is frame number that you capture
reopen VS and reconfig for your camera name and enjoy it
Smiley Wink
Message 12 of 18
(1,476 Views)
Thanks a lot.It is working perfectly.. 🙂
Message 13 of 18
(1,465 Views)
Hello Again,
I want to do another task as an extension of this one. So, I want to identify a pattern while capturing image and camera should capture the image in defined time (i.e. 1 minute), if not, it will shut down again.
So, camera will turn on, start looking for pattern within the frame, if it cannot find within 1 minute, it will shut down, but if it finds withing 1 minute, it will capture the image with pattern.
So, how can I achieve it ? Could you please help me!?
How can I stop one while loop in two ways(either camera stops or Elapsed time).!?
Thanks 🙂
Message 14 of 18
(1,449 Views)
Hello All,
Please ignore my previous question. I have found the solution of it by applying ''or'' Boolean. 🙂
Message 15 of 18
(1,443 Views)
Hello Again,
In addition to the solution provided in this post I want to develop one step more in same file.
I want to identify and count the pattern in the online show which I am able to do it in Vision Assistant. But since my object's position is not fixed, I have defined ROI and Co-ordinate system in Vision Assistant which works perfectly in it but ROI and Co-ordinate system are not working as I desired in VI Labview.
Could anyone please help me.
Thank you. 🙂
Message 16 of 18
(1,440 Views)
Hi based on forum rule you have to create new topic for your question to get answer
Message 17 of 18
(1,435 Views)
oh ... ok..thanks 🙂
Message 18 of 18
(1,430 Views)
